Date/Time: Sun, 19 May 2024 19:22:55 +0000
[Programming Help] - Add parameter TimeZone to Time Line study
View Count: 664
[2019-03-09 14:52:25] |
User972768 - Posts: 166 |
Hello, It would be great to have extra parameter TimeZone for the "Time Line" study. By default it should be set to global value (eg, US Eastern). Adding this parameter will help to chart lines that are time-zone dependant. Example would be Open/Close of European session for US traders. Since Europe and US do not switch Daylight Timing on the same day, it brings a bit of havoc to such studies. Thanks and best regards |
[2019-03-11 17:46:06] |
You will need to modify the study to do this: How to Build an Advanced Custom Study from Source Code ACSIL does have functions to do time zone conversions. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-11 17:46:15
