Date/Time: Sun, 19 May 2024 06:24:54 +0000
Can't switch back to March contract
View Count: 601
[2019-03-08 20:25:18] |
User158036 - Posts: 2 |
Having trouble going back to March contract from June, seems to be stuck on EPM19 everytime we try to change back on chart settings, if you can please provide a solution will be gladly appreciated. This happens only on one workspace, the other systems work as expected. ver 1842.
[2019-03-08 22:56:45] |
Disable this option: Chart Settings: Automatically Rollover Futures Symbol (Chart >> Chart Settings >> Symbol >> Symbol menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
