Date/Time: Sun, 19 May 2024 04:11:22 +0000
opening bar
View Count: 7264
[2019-03-08 19:40:25] |
User894467 - Posts: 19 |
Is there a chart setting where the bar printed at the open will not close the gap as in the attached screen shot? The long gap filling bar is skewing indicator data. I noticed that the gap filling bar is on the main instance of Sierra. When I open the same chart on a sub-instance the gap in not filled. Date Time Of Last Edit: 2019-03-08 20:33:37
Gap bar.png / V - Attached On 2019-03-08 19:40:14 UTC - Size: 5.56 KB - 292 views |
[2019-03-08 20:33:48] |
Are these Renko type bars? Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-03-08 20:45:12] |
This is a 1 min chart --> F.US.YMM19 http://www.sierrachart.com/image.php?Image=1552077876178.png |
[2019-03-08 22:58:55] |
You need to remove the filling of gaps. Refer to this chart setting: Chart Settings: Intraday Chart Bar Period >> Gap Fill (Chart >> Chart Settings >> Bar Period >> Intraday Chart Bar Period Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
