Date/Time: Sun, 28 Apr 2024 19:11:04 +0000
printing detached windows
View Count: 1288
[2013-11-17 23:20:56] |
Willson - Posts: 176 |
Simple things seem difficult. Can't seem to print a detached window. Have searched boards, no luck. Suggestions? Thanks |
[2013-11-17 23:32:00] |
What happens when you try?
[2013-11-17 23:32:32] |
Or is the problem that you cannot get to the Print command?
[2013-11-17 23:42:37] |
Yes, can't find the print command. I can find and use it with non-detached windows Thanks |
[2013-11-18 00:03:07] |
Press Control-P
[2013-11-18 00:45:47] |
Very clever :) Thanks, I have been using a prt-screen utility for years, forgot that windows had one. |
