Date/Time: Sat, 18 May 2024 20:36:46 +0000
Editing text/cell value alignment in spreadsheet study - how to
View Count: 655
[2019-03-08 16:23:43] |
User686258 - Posts: 7 |
If I am working with spreadsheet study and want to change the alignment left-center-right by clicking on a cell, and then going cell by cell from there as needed how can I do that? What is the equivalent- or the closest that I can come- to the way it is done in excel...ie. right click, font and then whatever else you want to do with the text. bold, color, etc. Thank you. |
[2019-03-08 17:30:38] |
Text alignment within a cell is not supported in Sierra Chart spreadsheets. But you can do other formatting by selecting the cells and then selecting the appropriate command from the Spreadsheet menu. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-08 17:31:25
