Date/Time: Sun, 19 May 2024 06:58:58 +0000
Rollover Gremlins !
View Count: 537
[2019-03-08 16:11:07] |
User11638 - Posts: 21 |
Hello, I have 2 copies of Sierra running on two different computers and the same problem has happened on both of them, co-incident with ROLLOVER. There are multiple charts in a chartbook which are not loading the correlated drawings file. Note that some of the charts are loading drawings and other charts are not. I keep backup copies of my chartbooks in Sierra, when I open the backup copies, the same problem is present. I have not saved any of the affected chartbooks since I noticed the problem. Thank you for your attention to this matter. |
[2019-03-08 16:25:20] |
Refer to: Changing to a New Futures Contract Month: Allowing Lines and Other Chart Drawings From Other Contract Months to Appear on the Current Contract Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
