Date/Time: Sat, 18 May 2024 23:30:49 +0000
Instance vs Additional Systems
View Count: 656
[2019-03-08 13:20:41] |
stever62 - Posts: 12 |
In the payment area, it says I have 2 systems and I can add more systems for a cost. I also read that I can create multiple instances with no limit. What is the difference between a system and an instance? Thanks |
[2019-03-08 16:36:06] |
This is explained here: Sierra Chart Purchase and License Information: Licensing / Number of Systems Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
