Date/Time: Sat, 18 May 2024 19:03:22 +0000
OHLC bars - How to get tick color to match bar color?
View Count: 1135
[2019-03-08 11:57:52] |
User462086 - Posts: 193 |
I'm still somewhat new to SC and can't find a way to get all components (open tick, bar, close tick) of an OHLC down bar to be red, and all of the components of an OHLC up bar to be green. I can set the bar colors to red and green but there appears to be a global tick color. In other words, the tick colors on the up and down bars seem to be forced to the same color. How can I accomplish this so there are only 2 colors for the OHLC bars: all parts of down bars are red, and all parts up bars are green? Many thanks!! |
[2019-03-08 23:12:38] |
This is the relevant setting for this: Graphics Settings: Color Entire OHLC Bar the High/Low Color (Global Settings >> Graphics Settings >> Other) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
