Date/Time: Thu, 22 Oct 2026 21:57:31 +0000
Chart drawings deleted by Sierra Chart
View Count: 1681
[2019-03-07 21:45:02]
User629461 - Posts: 213
Hi, all the chart drawings from some of my charts have been deleted and I did not delete them myself. I do not have any chart drawings hidden. Can you explain how this happened and advise how to recover and avoid in future as I do not want this happening again. Let me know what information/logs you need from me to understand what happened. Thanks
[2019-03-08 00:25:47]
The methods for deleting a chart drawing are documented here:
Chart Drawing Tools: Erasing Chart Drawings
So it must have been for one of those reasons.
There are backup Chartbook's available you can use to get the drawings back. Refer to:
Chartbooks (Workspaces): Accessing a Backup Chartbook File
[2019-03-08 03:49:08]
Make sure you have enabled this option:
Chart Drawing Tools: Prompt When Deleting All Chart Drawings (Global Settings >> Tool Settings >> General >> Other)
[2019-03-08 04:20:36]
I definitely didn't erase any chart drawings and it has happened across 4 charts, not a one-off occurrence. Have tried to restore a couple of older chartbooks as suggested but none of the drawings appear on any of the charts now (I have 12 charts in the chartbook). What I have noticed is the contract month has changed for ES (from H to M), would this have something to do with it? The charts in my original chartbook with code ESH19 still show drawings but those with ESM19 do not have any drawings anymore. Is this the problem?
[2019-03-08 05:14:43]
Ok you have now identified the problem. Follow the instructions here:
Changing to a New Futures Contract Month: Allowing Lines and Other Chart Drawings From Other Contract Months to Appear on the Current Contract
[2019-03-08 06:12:41]
That worked, thanks. What I noticed though is some charts show the drawings are shifted relative to price. Is this because historical prices have been adjusted to cater for the current contract trading at a premium or discount? If so, how can I plot the non-adjusted price? And, are there parameters which can be set as to when to flip to the next contract (ie based on trading volume) or is this done automatically based on scheduled rollover date? Thanks
[2019-03-08 16:03:00]
You can adjust the drawings as you require. Refer to:
Changing to a New Futures Contract Month: Adjusting Chart Drawings to Match Futures Contract Rollover Difference
This is also answered in the section above.
Refer to:
Changing to a New Futures Contract Month: Enabling/Disabling Automatic Rollover
Date Time Of Last Edit: 2019-03-08 16:03:33
