Date/Time: Sun, 19 May 2024 13:24:43 +0000
Number bars calculated values - averages
View Count: 1084
[2019-03-07 14:26:01] |
User661434 - Posts: 27 |
Hi, I am setting up a chart with number bars, I have added the calculated Values study, Delta, Candle Vol, Vol Bar Diff. (see pic) Is there also a possibility to print the AVERAGE volume of a candle? (over a certain period, for example the last 100 bars...) Thanks for looking at this. |
tick average - Attached On 2019-03-07 14:25:20 UTC - Size: 69.51 KB - 294 views Attachment Deleted. |
[2019-03-07 18:07:58] |
John - SC Support - Posts: 31708 |
You can use the data in the Numbers Bars Calculated Values as part of a Moving Average to get what you want. For example, if you have the Numbers Bars Calculated Values on the chart, then add a Moving Average - Simple (or other Moving Average of your choice) to the chart in a separate Chart Region and set the Based On Input to the Numbers Bars Calculated Values and select the appropriate Subgraph (such as Volume) for the Input Data Input and then set the Length to 100. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
