Date/Time: Sun, 19 May 2024 20:36:20 +0000
[Programming Help] - How do i Setup limit order
View Count: 667
[2019-03-06 21:22:32] |
1234567 - Posts: 42 |
hey i wounding how do i setup an market order and limit order (trailing stop) with the SPREADSHEETS, for the market order column K and M. And limit order (trailing stop) for L and N. do i need the Chart DOM or can i just use SPREADSHEETS only. In the SPREADSHEETS is says "(read/write)" what does that mean. how does it work? thank you |
[2019-03-06 22:55:47] |
Are you referring to having a Target and Stop order submitted with a market entry order? If so, refer to: Spreadsheet Systems, Alerts and Automated Trading: Initiating Trades with Auto-Trading and Using Manual or Attached Orders Exits Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-03-08 01:27:06] |
1A: how do i setup an market order and limit order (trailing stop) with the SPREADSHEETS, for the market order column K and M. And limit order (trailing stop) for L and N. 1B: do i need the Chart DOM or can i just use SPREADSHEETS only 2: In the SPREADSHEETS is says "(read/write)" what does that mean. how does it work? in column I And J. thank you |
[2019-03-11 03:20:00] |
please help i need to know how to do this. 1A: how do i setup an market order and limit order (trailing stop) with the SPREADSHEETS, for the market order column K and M. And limit order (trailing stop) for L and N. 1B: do i need the Chart DOM or can i just use SPREADSHEETS only 2: In the SPREADSHEETS is says "(read/write)" what does that mean. how does it work? in column I And J. |
[2019-03-11 04:22:09] |
Sawtooth - Posts: 4001 |
1A: The order type is set in cells J71-J74, and the Limit price is set in cells J22-J25, usually with a formula. You don't need a price in J22-J25 for Market orders. Spreadsheet Systems, Alerts and Automated Trading: Limit or Stop Prices [J22, J23, J24, J25] Spreadsheet Systems, Alerts and Automated Trading: Buy Entry: Order Type [J71] 1B: You don't need the ChartDOM, but it is much easier to use the Trade Window's Attached Orders for the trailing stop, if the trailing stop is not based on a spreadsheet formula. Attached Orders If the trailing stop is based on a spreadsheet formula, you should still use Attached Orders, and move the stop with the Trade Management by Study study referencing a formula (that returns a price) in row 3 of a Formula Column. This allows a protective stop to be at the exchange. Attached Orders: Study Controlled Targets and Stops 2: Read/Write and Write-Only cells in column J can contain user formulas or values that the system will use. Read-Only cells are system generated and cannot be altered by the user, but they can be referenced. |
