Date/Time: Sun, 19 May 2024 14:55:06 +0000
Pivot points daily
View Count: 1127
[2019-03-06 21:14:06] |
Dennis B. - Posts: 263 |
I have 3 instances of SC and I put the pivot points on identical charts on all 3 of them for the E-mini. You did some kind of delete and download today and now I have different pivot points levels on the charts..off about a point. Installed version 1880 but no change. Same study parameters on all 3. Trading ESH19 only.
[2019-03-06 23:07:49] |
You did some kind of delete and download today We do not know what you are referring to in regards to this.Refer to this page for help: Pivot Points are not Accurate or are Different We also see you are using IQ Feed. You should be using the Sierra Chart Exchange Data Feed instead: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-03-07 14:10:55] |
Can't figure out the cost if switch to SC data feed. TI have 3 instances of SC and to not use the trading platform, I would need access TO CME/Globex data,nothing else. Have #3 service package.
[2019-03-07 14:17:36] |
Forget it, I don't use one of your approved trading services.
