Date/Time: Sun, 19 May 2024 16:25:54 +0000
Floating ControlBar vanished
View Count: 563
[2019-03-06 10:21:04] |
nicktrader - Posts: 665 |
I use six monitors. I had to remove monitor #6 because it was broken. Now I have the problem that I cannot navigate ControlBar#2 (floating) because it was placed on Monitor #6. What can I do? |
[2019-03-06 17:42:00] |
Refer to this section here on what to do: Control Bar: Unable to Make Control Bar Visible This is the very last section. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
