Date/Time: Tue, 28 May 2024 23:08:32 +0000
TPO profiles - Peaks and Valleys - BUG
View Count: 846
[2019-03-05 19:25:46] |
User365411 - Posts: 179 |
I have just updated SC from 1853 to 1880. In TPO charts the Peaks and Valleys doesn't works correctly when "Include High/Low in Peaks and Valleys" is set to Yes and "Extend Peaks and Valleys" is set as "Until Future Intersection". Images attached, same chartbook. Reverting back to 1853 problem disappear. I don't know when things changed but probably something goes wrong with the 1871 release when you added this feature "Added support for peak and valley lines on the Volume by Price study when used with the TPO Profile chart study." Can you check? TY |
version1853_Sierra Chart MainWindow 2019-03-05 20_00_30.846.png / V - Attached On 2019-03-05 19:24:34 UTC - Size: 172.36 KB - 365 views version1880_Sierra Chart MainWindow 2019-03-05 20_04_51.424.png / V - Attached On 2019-03-05 19:24:44 UTC - Size: 198.66 KB - 266 views |
[2019-03-07 01:45:20] |
We are checking on this.
[2019-03-07 02:20:20] |
This will be resolved in version 1882.
