Date/Time: Mon, 06 May 2024 16:40:04 +0000
DIFFERENT setting of the right and left scales FOR DIFFERENT CHARTS
View Count: 1869
[2019-03-05 06:50:41] |
User14686603 - Posts: 14 |
how to make it so that on the left scale you could control the scale and zero mark of one chart and on the right scale you can control the scale and zero mark of the other chart INDEPENDENT |
RIGHT LEFT SCALE FOR DIFFERENT CHARTS.png / V - Attached On 2019-03-05 06:48:02 UTC - Size: 76.75 KB - 493 views |
[2019-04-25 10:20:27] |
User462086 - Posts: 188 |
have just run into the same issue. having numbers print on a left scale is better than nothing but why not finish the job by making it interactive? i'm pretty sure i saw a post on this forum dating back to 2016 on the same issue. ETA was "in about a year." found it: Left side scale Date Time Of Last Edit: 2019-04-25 12:40:23
[2019-04-25 18:08:22] |
Okay we will try to get this supported very soon.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-25 18:08:45
[2019-04-26 11:36:41] |
perhaps on the study "setting and inputs" tab there could be a check box for "use left scale" (see attached png). when checked the left scale would be shown on the chart for that study, and the left scale would be linked to that study's "scale" settings from the same "setting and inputs" tab = very intuitive for a busy trader. in addition, the left scale could be dragged and resized in the same way as the right scale (eg, LCLICK+DRAG for vertical movement and CTRL+LCLICK+DRAG for vertical scaling). thanks a lot for bumping this up on your list!! Date Time Of Last Edit: 2019-04-26 11:38:58
StudySettings_UseLeftScale.png / V - Attached On 2019-04-26 11:35:52 UTC - Size: 29.81 KB - 311 views |
[2019-04-27 01:00:39] |
We will see about this. The initial release of the left side scale control is out in the latest prerelease. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-27 01:03:30
[2019-04-27 05:41:08] |
thank you for getting a start on this so quickly. if i put a couple of studies in region 2 & set each study's scale to "independent" or "automatic" the left scale will function just like the right scale does when dragged. have i gotten this correct so far?
[2019-04-29 03:40:31] |
Haven't heard back on my previous email so let me just clarify that the point of this thread is to have independent left and right scales: independent scaling and independent moving. Currently the left scale and right scale are not independent: they move and scale together. I understand this is the initial release and there's more work to be done.
[2019-04-29 21:14:56] |
We are releasing a new revision of 1913 where this now works properly but it is necessary when using the left side scale that the graph which is setting those scale values has a Scale Range of Independent.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-29 21:15:19
[2019-04-30 15:12:01] |
thank you for the update. please see attached animated gif for current behavior on my machine. once the left scale has been adjusted either by moving it or scaling it, the scale snaps back to its original location. also, if the price series is moved, then the left scale series will snap to the new price series location. maybe i've got something set wrong...? edit: looks like the gif won't upload Date Time Of Last Edit: 2019-04-30 15:22:54
[2019-05-01 03:27:52] |
A video is not helpful: Support Board Posting Information: Do Not Post Videos Unless Requested! We cannot reproduce anything like this. It does not make sense either. Provide that chart by following these instructions here: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-01 03:29:17
[2019-05-01 03:39:15] |
thanks for the heads-up on the video. i've attached a chartbook per your instructions.
LeftScale_v1914.Cht - Attached On 2019-05-01 03:38:04 UTC - Size: 30.34 KB - 276 views |
[2019-05-03 10:30:18] |
User745789 - Posts: 173 |
I wont post a gif/video either, per the rules, but I am also having problems with this. I can independently re-scale the LHS/RHS with my cursor. But when I let go of the mouse click, the re-scale reverts back. 1913. LHS scale = independent Date Time Of Last Edit: 2019-05-03 11:18:04
[2019-05-03 11:11:16] |
This problem will be resolved in the next release.
