Date/Time: Mon, 20 May 2024 00:17:55 +0000
Cannot install Sierra Chart
View Count: 742
[2019-03-03 14:11:56] |
Ulaju - Posts: 56 |
Maximum number of retries encountered. Refer to log. Download canceled. Socket gracefully closed by remote side Closed I already deactivated the antivirus. What else can I do? |
[2019-03-03 18:49:53] |
Sierra Chart - Max - Posts: 5618 |
Please try again and provide us the Installer Log: Software Download: Providing Installer Log to Support Just attach it to this support request instead of starting a new one. Sierra Chart Support Date Time Of Last Edit: 2019-03-03 18:50:42
[2019-03-04 16:39:02] |
Ulaju - Posts: 56 |
Ok done. Here it is.
Private File |
[2019-03-06 07:11:53] |
We have looked at this installer log and this is what we are seeing: HTTPS www.sierrachart.com:443 (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2019-03-04 23:44:51 You are experiencing network connectivity issues with the downloading of the files. So this is a problem with your Internet connection and that is why the installation is not succeeding. Could you try a different Internet connection. Or try again another time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-06 07:13:10
