Date/Time: Tue, 15 Jul 2025 19:08:43 +0000
Trading live (real money) on new SC data feed past 3 days, with excellent results.
View Count: 2525
[2013-11-15 21:28:05] |
jsoviero - Posts: 84 |
Thank you SC engineers (Max) for delivering what I believe is by far the best trading platform, bar none, and now with your own SC data feed! I am confident enough in your expertise to have cancelled my subscription to another very famous, expensive data feed (saving $100 per month) and now I am happily, completely and totally in the Sierra Charts camp. I also want to give a "shout out" to Tom Gilb, who held my hand during the steep learning curve. Congratulations SC, from a loyal, appreciative subscriber! |
[2013-11-15 21:34:19] |
C. Notes - Posts: 130 |
Amen
[2013-11-15 22:01:32] |
Thank you for the feedback.
[2013-12-18 16:03:47] |
brando - Posts: 14 |
Is the ECBOT streaming futures data,trading thru IB, now available from Sierra? I wasn't quite sure from reading the posts.
[2013-12-18 17:46:52] |
Yes.
[2014-01-20 18:33:49] |
Trakot57 - Posts: 8 |
Has this data its own TICK calculation already? Or after purchase will I still get not as good TICK data from my broker? Thanks.
[2014-01-20 18:34:32] |
No not yet. This is currently under active development. It should be out hopefully in about a week or so. What broker are you comparing the current $TICK to? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-20 19:31:50] |
I use Infinity data and I can`t rely on TICK at all especially during first half an hour or so. To demonstrate that I attach my TICK and correct TICK from January 16th. |
[2014-01-20 19:51:06] |
Thank you for the feedback. We are going to be certain the new $TICK will be well calculated.
