Date/Time: Sun, 19 May 2024 05:43:33 +0000
adding premium es-spx
View Count: 630
[2019-03-02 20:40:13] |
miker - Posts: 7 |
I have futures data with stage 5 and a annual subscription. After reading everything do I need to active a 35$ 1st active user month plan to get 5$ month sp index data? I have to be mistaken on that? https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures#DataConnections |
[2019-03-02 22:56:43] |
The cost would be 25 USD a-month for 20 symbols and you need to activate two different exchanges and that is explained in detail here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#StockIndexPremiums Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-03-03 20:33:05] |
miker - Posts: 7 |
I have already have futures data and only need the sp index for 5$ a month. However it seems I have to buy 25$ 20 symbols then 15 cme fee and a 5$ data to get it through you???? So that 45$ a month for one symbol? Is that correct?
[2019-03-03 20:43:15] |
Yes that is correct. These are the rules imposed by exchanges. This is the circumstance that exchanges create and insist upon. Although the CME fee in this case would only be 3.25 USD. You do not need to pay for market depth.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-03 20:43:52
