Date/Time: Thu, 02 May 2024 22:19:17 +0000
How to reference all visible bars in alert?
View Count: 1591
[2019-03-02 15:00:19] |
User462086 - Posts: 188 |
I'd like to color volume bars based on height relative to the tallest bar that is currently visible. Something like this (each line would trigger a different color): V >= 0.8 * maximum visible value AND( V >= 0.6 * max visible value, V < 0.8 * maximum visible value ) AND( V >= 0.4 * max visible value, V < 0.6 * maximum visible value ) AND( V >= 0.2 * max visible value, V < 0.4 * maximum visible value ) V < 0.2 * maximum visible value I've found the page that talks about how to reference a range, something like [0:-10], but I can't find documentation for setting the lookback based on visible bar count. Many thanks!! |
[2019-03-04 04:21:51] |
Hi Ackin, thank you very much. I went to your forum and found that it requires registration to access the code. Is it possible to post the code on this forum too? Many thanks!!
[2019-03-07 06:00:31] |
Hi Ackin, your forum sounds valuable! I'll check it out. And thank you again for helping.
