Date/Time: Sun, 19 May 2024 07:51:27 +0000
SC Data & instances connected to different trading services
View Count: 524
[2019-03-02 11:32:37] |
User907968 - Posts: 804 |
Hi support, Using the functionality described in the link below - https://www.sierrachart.com/index.php?page=doc/MultipleServices.html#AccessingMarketDataFromOtherInstancesOfSierra%20Chart Is it possible to setup a server instance of SC that is connected to 'SC Data - All Services' and then feed this data to other instances of SC that are connected to different trading services? What I would like to achieve is to use SC data feed and a non-trading instance of SC to test EUREX data, whilst also maintaining connection to SC data in CTS and/or Transact instances. If it is technically feasible, but beyond the scope of support, that is understandable, I am happy to proceed in the knowledge that I am on my own. However, if it is simply not possible to do as I describe and instead I should setup a second connection, then this is something I will consider. Thanks. |
[2019-03-02 23:40:49] |
Yes this is supported. And you have the relevant documentation.
