Date/Time: Fri, 03 May 2024 01:01:55 +0000
Volume study irregularities
View Count: 1196
[2013-11-15 17:44:08] |
Does not make much sense that there would be no volume for a particular bar. Of course we do not know what Data or Trading service is being used or the symbol. Please provide an image of the chart, by following these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-11-15 19:37:58] |
Do you see volume for each bar if you have the Volume study all by itself in its own Chart Region?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-11-18 14:37:30
