Date/Time: Fri, 06 Nov 2026 18:27:55 +0000
High/Low for Time Period Extended
View Count: 924
[2019-02-28 16:59:12]
User982736 - Posts: 46
I have several of these studies on one chart for different time periods and I would like to be able to tell them apart on the chart by using the Text to Draw on the study but they are grayed out.
Any way to enable this?
[2019-02-28 19:12:07]
John - SC Support - Posts: 48456
The Text to Draw is not what you want to use. That is for studies that display text only. For this you can use either the Name Label on the Subgraph tab, or use the Text Display for Study study. Which one you use just depends on which you prefer visually.
The documentation for the Name Label is here:
Chart Studies: Subgraphs Tab >> Name and Value Labels
The documentation for the Text Display for Study study is here:
Text Display For Study
[2019-02-28 19:41:10]
Thanks. Short name was exactly what I wanted.
