Date/Time: Fri, 06 Nov 2026 18:27:51 +0000
Historical 6C Chart
View Count: 988
[2019-02-28 16:18:25]
infpz - Posts: 826
Issues - see below please.
The D6H99.dly symbol may not be the active contract month. | 2019-02-28 11:02:08
Unable to determine transition date based on volume from files: D6H99.dly, D6M99.dly | 2019-02-28 11:02:08
The D6M99.dly symbol may not be the active contract month. | 2019-02-28 11:02:08
Unable to determine transition date based on volume from files: D6M99.dly, D6U99.dly | 2019-02-28 11:02:08
The D6U99.dly symbol may not be the active contract month. | 2019-02-28 11:02:08
Unable to determine transition date based on volume from files: D6U99.dly, D6Z99.dly | 2019-02-28 11:02:08
The D6Z99.dly symbol may not be the active contract month. | 2019-02-28 11:02:08
Unable to determine transition date based on volume from files: D6Z99.dly, D6H00.dly | 2019-02-28 11:02:08
The D6H00.dly symbol may not be the active contract month. | 2019-02-28 11:02:08
Unable to determine transition date based on volume from files: D6H00.dly, D6M00.dly | 2019-02-28 11:02:08
The D6M00.dly symbol may not be the active contract month. | 2019-02-28 11:02:08
Unable to determine transition date based on volume from files: D6M00.dly, D6U00.dly | 2019-02-28 11:02:08
The D6U00.dly symbol may not be the active contract month. | 2019-02-28 11:02:08
Unable to determine transition date based on volume from files: D6U00.dly, D6Z00.dly | 2019-02-28 11:02:08
The D6Z00.dly symbol may not be the active contract month. | 2019-02-28 11:02:08
Unable to determine transition date based on volume from files: D6Z00.dly, D6H01.dly | 2019-02-28 11:02:08
The D6H01.dly symbol may not be the active contract month. | 2019-02-28 11:02:08
Unable to determine transition date based on volume from files: D6H01.dly, D6M01.dly | 2019-02-28 11:02:08
The D6M01.dly symbol may not be the active contract month. | 2019-02-28 11:02:08
Unable to determine transition date based on volume from files: D6M01.dly, D6U01.dly | 2019-02-28 11:02:08
The D6U01.dly symbol may not be the active contract month. | 2019-02-28 11:02:08
Unable to determine transition date based on volume from files: D6U01.dly, D6Z01.dly | 2019-02-28 11:02:08
The D6Z01.dly symbol may not be the active contract month. | 2019-02-28 11:02:08
Unable to determine transition date based on volume from files: D6Z01.dly, D6H02.dly | 2019-02-28 11:02:08
The D6H02.dly symbol may not be the active contract month. | 2019-02-28 11:02:08
Unable to determine transition date based on volume from files: D6H02.dly, D6M02.dly | 2019-02-28 11:02:08
The D6M02.dly symbol may not be the active contract month. | 2019-02-28 11:02:08
Unable to determine transition date based on volume from files: D6M02.dly, D6U02.dly | 2019-02-28 11:02:08
The D6U02.dly symbol may not be the active contract month. | 2019-02-28 11:02:08
Unable to determine transition date based on volume from files: D6U02.dly, D6Z02.dly | 2019-02-28 11:02:08
The D6Z02.dly symbol may not be the active contract month. | 2019-02-28 11:02:08
Unable to determine transition date based on volume from files: D6Z02.dly, D6H03.dly | 2019-02-28 11:02:08
The D6H03.dly symbol may not be the active contract month. | 2019-02-28 11:02:08
Unable to determine transition date based on volume from files: D6H03.dly, D6M03.dly | 2019-02-28 11:02:08
The D6M03.dly symbol may not be the active contract month. | 2019-02-28 11:02:08
Unable to determine transition date based on volume from files: D6M03.dly, D6U03.dly | 2019-02-28 11:02:08
The D6U03.dly symbol may not be the active contract month. | 2019-02-28 11:02:08
Unable to determine transition date based on volume from files: D6U03.dly, D6Z03.dly | 2019-02-28 11:02:08
The D6Z03.dly symbol may not be the active contract month. | 2019-02-28 11:02:08
Unable to determine transition date based on volume from files: D6Z03.dly, D6H04.dly | 2019-02-28 11:02:08
The D6H04.dly symbol may not be the active contract month. | 2019-02-28 11:02:08
Unable to determine transition date based on volume from files: D6H04.dly, D6M04.dly | 2019-02-28 11:02:08
The D6M04.dly symbol may not be the active contract month. | 2019-02-28 11:02:08
Unable to determine transition date based on volume from files: D6M04.dly, D6U04.dly | 2019-02-28 11:02:08
The D6U04.dly symbol may not be the active contract month. | 2019-02-28 11:02:08
Unable to determine transition date based on volume from files: D6U04.dly, D6Z04.dly | 2019-02-28 11:02:08
The D6Z04.dly symbol may not be the active contract month. | 2019-02-28 11:02:08
Unable to determine transition date based on volume from files: D6Z04.dly, D6H05.dly | 2019-02-28 11:02:08
The D6H05.dly symbol may not be the active contract month. | 2019-02-28 11:02:08
Unable to determine transition date based on volume from files: D6H05.dly, D6M05.dly | 2019-02-28 11:02:08
The D6M05.dly symbol may not be the active contract month. | 2019-02-28 11:02:08
Unable to determine transition date based on volume from files: D6M05.dly, D6U05.dly | 2019-02-28 11:02:08
The D6U05.dly symbol may not be the active contract month. | 2019-02-28 11:02:08
Unable to determine transition date based on volume from files: D6U05.dly, D6Z05.dly | 2019-02-28 11:02:08
The D6Z05.dly symbol may not be the active contract month. | 2019-02-28 11:02:08
Unable to determine transition date based on volume from files: D6Z05.dly, D6H06.dly | 2019-02-28 11:02:08
The D6H06.dly symbol may not be the active contract month. | 2019-02-28 11:02:08
Unable to determine transition date based on volume from files: D6H06.dly, D6M06.dly | 2019-02-28 11:02:08
The D6M06.dly symbol may not be the active contract month. | 2019-02-28 11:02:08
Unable to determine transition date based on volume from files: D6M06.dly, D6U06.dly | 2019-02-28 11:02:08
The D6U06.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6U06.dly, D6Z06.dly | 2019-02-28 11:02:09
The D6Z06.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6Z06.dly, D6H07.dly | 2019-02-28 11:02:09
The D6H07.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6H07.dly, D6M07.dly | 2019-02-28 11:02:09
The D6M07.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6M07.dly, D6U07.dly | 2019-02-28 11:02:09
The D6U07.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6U07.dly, D6Z07.dly | 2019-02-28 11:02:09
The D6Z07.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6Z07.dly, D6H08.dly | 2019-02-28 11:02:09
The D6H08.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6H08.dly, D6M08.dly | 2019-02-28 11:02:09
The D6M08.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6M08.dly, D6U08.dly | 2019-02-28 11:02:09
The D6U08.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6U08.dly, D6Z08.dly | 2019-02-28 11:02:09
The D6Z08.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6Z08.dly, D6H09.dly | 2019-02-28 11:02:09
The D6H09.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6H09.dly, D6M09.dly | 2019-02-28 11:02:09
The D6M09.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6M09.dly, D6U09.dly | 2019-02-28 11:02:09
The D6U09.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6U09.dly, D6Z09.dly | 2019-02-28 11:02:09
The D6Z09.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6Z09.dly, D6H10.dly | 2019-02-28 11:02:09
The D6H10.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6H10.dly, D6M10.dly | 2019-02-28 11:02:09
The D6M10.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6M10.dly, D6U10.dly | 2019-02-28 11:02:09
The D6U10.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6U10.dly, D6Z10.dly | 2019-02-28 11:02:09
The D6Z10.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6Z10.dly, D6H11.dly | 2019-02-28 11:02:09
The D6H11.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6H11.dly, D6M11.dly | 2019-02-28 11:02:09
The D6M11.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6M11.dly, D6U11.dly | 2019-02-28 11:02:09
The D6U11.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6U11.dly, D6Z11.dly | 2019-02-28 11:02:09
The D6Z11.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6Z11.dly, D6H12.dly | 2019-02-28 11:02:09
The D6H12.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6H12.dly, D6M12.dly | 2019-02-28 11:02:09
The D6M12.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6M12.dly, D6U12.dly | 2019-02-28 11:02:09
The D6U12.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6U12.dly, D6Z12.dly | 2019-02-28 11:02:09
The D6Z12.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6Z12.dly, D6H13.dly | 2019-02-28 11:02:09
The D6H13.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6H13.dly, D6M13.dly | 2019-02-28 11:02:09
The D6M13.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6M13.dly, D6U13.dly | 2019-02-28 11:02:09
The D6U13.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6U13.dly, D6Z13.dly | 2019-02-28 11:02:09
The D6Z13.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6Z13.dly, D6H14.dly | 2019-02-28 11:02:09
The D6H14.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6H14.dly, D6M14.dly | 2019-02-28 11:02:09
The D6M14.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6M14.dly, D6U14.dly | 2019-02-28 11:02:09
The D6U14.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6U14.dly, D6Z14.dly | 2019-02-28 11:02:09
The D6Z14.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6Z14.dly, D6H15.dly | 2019-02-28 11:02:09
The D6H15.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6H15.dly, D6M15.dly | 2019-02-28 11:02:09
The D6M15.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6M15.dly, D6U15.dly | 2019-02-28 11:02:09
The D6U15.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6U15.dly, D6Z15.dly | 2019-02-28 11:02:09
The D6Z15.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6Z15.dly, D6H16.dly | 2019-02-28 11:02:09
The D6H16.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6H16.dly, D6M16.dly | 2019-02-28 11:02:09
The D6M16.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6M16.dly, D6U16.dly | 2019-02-28 11:02:09
The D6U16.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6U16.dly, D6Z16.dly | 2019-02-28 11:02:09
The D6Z16.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6Z16.dly, D6H17.dly | 2019-02-28 11:02:09
The D6H17.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6H17.dly, D6M17.dly | 2019-02-28 11:02:09
The D6M17.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6M17.dly, D6U17.dly | 2019-02-28 11:02:09
The D6U17.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6U17.dly, D6Z17.dly | 2019-02-28 11:02:09
The D6Z17.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6Z17.dly, D6H18.dly | 2019-02-28 11:02:09
The D6H18.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6H18.dly, D6M18.dly | 2019-02-28 11:02:09
The D6M18.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6M18.dly, D6U18.dly | 2019-02-28 11:02:09
The D6U18.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6U18.dly, D6Z18.dly | 2019-02-28 11:02:09
The D6Z18.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
Unable to determine transition date based on volume from files: D6Z18.dly, 6CH9.dly | 2019-02-28 11:02:09
The 6CH9.dly symbol may not be the active contract month. | 2019-02-28 11:02:09
[2019-02-28 18:23:23]
There must be incomplete data in those files. Follow the instructions here:
