Date/Time: Sun, 19 May 2024 23:57:05 +0000
Chart with study - save and auto set different Inputs for each sybmol
View Count: 857
[2019-02-27 18:29:35] |
User624750 - Posts: 27 |
Hello! For example - I have chart with Simple Moving Average (SMA) Study. And I use this chart for CL, ES and GC symbols. Is it possible to set different Length of SMA for each Symbol - 5 for CL, 6 for ES, 7 for GC. When I change symbol, the Length of SMA changing too. I mean I set Study's Inputs for active symbol, Sierra Chart remember this and apply it when I return to this symbol again. Thanks in advance |
[2019-02-27 18:40:05] |
No, this is not supported.
