Date/Time: Sun, 19 May 2024 17:10:58 +0000
multiple SierraChartInstance
View Count: 908
[2019-02-27 14:44:09] |
User420296 - Posts: 12 |
Hello, If i open 4 instances of SC on a single Windows 10 using File->New Instance, the 2nd instance is missing my custom indicators and chartbooks. Instances 1,3,4 are fine. Please advise if i am missing something. Thanks |
[2019-02-27 16:26:24] |
bradh - Posts: 859 |
I believe the studies are copied from the first instance when each additional instance is created. If you created instance 2 some time ago, it may not be up to date. If you just created 3 and 4, then they got the latest studies, chartbooks, etc. I would try deleting instance 2 and then creating a new instance. I don't know what number it will be, but it should get everything from the first. |
[2019-02-27 16:38:52] |
That worked, live and learn. Thanks Brad.
[2019-02-27 17:06:17] |
I spoke too soon. The new instance is giving a "Windows error code 126: The specified module could not be found. Likely missing dependency file.". I have custom 3rd party indicators that use .lib files and they are not being moved to the new instance. Is there a setting somewhere to account for copying .lib files?
[2019-02-27 18:23:17] |
No these have to be manually moved . Also, we will also make sure that DLL files are always updated in a sub instance and any new ones are copied as well. We thought this is the case. Update: This was not the case, and will be the case effective with version 1881. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-27 18:32:28
