Date/Time: Sun, 28 Apr 2024 22:47:14 +0000
Market Depth Historical Graph Only After Last Bar
View Count: 1185
[2019-02-26 20:02:05] |
tdd2672 - Posts: 54 |
Is there or can there be an option for the market depth historical graph to only be displayed after the last bar and not on the rest of the chart?
[2019-02-26 20:03:26] |
Or can the chart dom be highlighted at those levels?
[2019-02-28 15:40:18] |
SC, any things on this? I would like to have this option so just the fill space is showing current levels based on my settings. DUe to my style of trading I have no need for the entire chart to be populated with this info.
[2019-04-25 18:08:41] |
To begin with, it is not possible to display the coloring for the Market Depth Historical Graph only after the last bar. That is not currently supported. It is possible, however, to display just the values from the last bar in the fill space to the right. This is an option that has been available for a few months now and is one of the selections under the Input Setting named Show Quantity Numbers. You would select the option Only After Last Bar. Here is the documentation for this setting: Market Depth Historical Graph: Show Quantity Numbers If you also want to not display any of the colors, then you would just need to set the colors to the same color as the background of your chart. Also, the depth information is available in the Chart DOM. Refer to the following for how to display this: https://www.sierrachart.com/index.php?page=doc/ChartTrading.html#MarketDepth For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-06 17:45:47] |
TopGunTrader - Posts: 136 |
I was just going to ask this question but found this on support forum. This is a real shame because everything that happened in the past is NOT relelevant to trades right now and it has a fast decay. What happened in last 5 secs is 3x more important than 30 secs ago and 100x more than 3 mins ago There NEEDS to be a setting show for X bars back. Chart pic will tell the story LEFT one is as it is now. RIGHT side has 2 charts same time frame so the market depth doesn't make the chart completely unreadable. Please consider fixing this. |
Capture.PNG / V - Attached On 2023-01-06 17:43:10 UTC - Size: 369.96 KB - 77 views |
[2023-02-08 15:59:06] |
User214239 - Posts: 19 |
I'm just adding in here that I also would like the option to have the market depth historical graph only be displayed after the last bar and not on the rest of the chart. That would be a useful feature update for me for how I use it on my chart DOM. Please consider adding it as an update to a future release. Thank you.
