Date/Time: Sun, 19 May 2024 21:31:23 +0000
SC data for CL on NYMEX
View Count: 593
[2019-02-26 18:47:25] |
tdug - Posts: 124 |
Hi, I use Amp as my broker. I want to use SC for charting and SC for live realtime NYMEX data. Amp have given me CQG data connection credentials to use. However when I use them in the CDQG Fix connection they don't work. Is this the right way to go about routing executions to Amp using your data? Many thanks |
[2019-02-26 18:48:29] |
Yes you can use CQG FIX or just use the CQG Web API Service setting in Sierra Chart. Either way. We need to see the Message Log. Provide a copy of the Message Log by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-26 18:48:58
[2019-02-26 18:51:56] |
tdug - Posts: 124 |
Reading Internal Order ID file. | 2019-02-26 18:47:30 Reading Trade Orders file. | 2019-02-26 18:47:30 Reading Trade Positions file. | 2019-02-26 18:47:30 Account Balance file. | 2019-02-26 18:47:30 Listening on UDP port 22904. | 2019-02-26 18:47:30 Software version: 1859 64-bit | 2019-02-26 18:47:30 Usage end date: 2019-04-10 | 2019-02-26 18:47:30 Enabled for: Advanced Features. | 2019-02-26 18:47:30 Enabled for: Advanced Features 2. | 2019-02-26 18:47:30 Enabled for: Sierra Chart Historical Data Service. | 2019-02-26 18:47:30 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2019-02-26 18:47:30 Enabled for: INDEXES_DATA_BARCHART | 2019-02-26 18:47:30 Enabled for: NYMEX with Market Depth for nonprofessional Trading accounts | 2019-02-26 18:47:30 Received 1 data feed usernames. | 2019-02-26 18:47:30 Allow Support for Sierra Chart Data Feeds is enabled. | 2019-02-26 18:47:30 Current selected Data/Trading service: CQG FIX Trading | 2019-02-26 18:47:30 Chart Update Interval: 10 | 2019-02-26 18:47:30 Time Zone: +00:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) | 2019-02-26 18:47:30 2019-02-26 18:47:30 Local computer time | 2019-02-26 18:47:30 2019-02-26 18:47:30 Local computer time in UTC | 2019-02-26 18:47:30 2019-02-26 18:47:30 Local computer time in SC Time Zone | 2019-02-26 18:47:30 2019-02-26 18:47:30 Server time in UTC | 2019-02-26 18:47:30 Local computer UTC time and Server UTC time difference: 1 seconds. | 2019-02-26 18:47:30 Program path: C:\SierraChart\ | 2019-02-26 18:47:30 Data Files path: C:\SierraChart\Data\ | 2019-02-26 18:47:30 OS Version Number: 10.0 | 2019-02-26 18:47:30 Locale Setting: C | 2019-02-26 18:47:30 DLLs: Trade29CustomStudies.dll, Trade29CustomStudies_64.dll, UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-02-26 18:47:30 Checking for new symbol settings. Requested symbol settings MD5 for service code cqg. Request ID: 1. | 2019-02-26 18:47:30 HTTPS www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2019-02-26 18:47:30 HTTPS www.sierrachart.com:443 (4) | Connecting to IP: 46.4.97.203. | 2019-02-26 18:47:30 Received 5 login tokens. | 2019-02-26 18:47:30 Symbol settings MD5 received. Request ID: 1. | 2019-02-26 18:47:30 Symbol settings are up-to-date for cqg. | 2019-02-26 18:47:30 HTTPS www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2019-02-26 18:47:32 HTTPS www.sierrachart.com:443 (5) | Connecting to IP: 46.4.97.203. | 2019-02-26 18:47:32 Files to Open on Start up | Opening file: Tim Master.Cht | 2019-02-26 18:47:33 CLJ9-NYMEX [CS] Yearly #15 | Reloading chart. | 2019-02-26 18:47:33 CLJ9-NYMEX [CS] Yearly #15 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-02-26 18:47:33 CLJ9-NYMEX [CS] Yearly #15 | There are no continuous futures contract symbols. Loading data normally. | 2019-02-26 18:47:33 CLJ9-NYMEX [CBV] 1000 Volume #5 | Reloading chart. | 2019-02-26 18:47:33 CLJ9-NYMEX [CBV] 1000 Volume #5 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-02-26 18:47:33 CLJ9-NYMEX [CBV] 1000 Volume #5 | There are no continuous futures contract symbols. Loading data normally. | 2019-02-26 18:47:33 CLJ9-NYMEX [CBV] 1000 Volume #6 | Reloading chart. | 2019-02-26 18:47:33 CLJ9-NYMEX [CBV] 1000 Volume #6 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-02-26 18:47:33 CLJ9-NYMEX [CBV] 1000 Volume #6 | There are no continuous futures contract symbols. Loading data normally. | 2019-02-26 18:47:33 CLJ9-NYMEX [CBV] 1 Min #19 | Reloading chart. | 2019-02-26 18:47:33 CLJ9-NYMEX [CBV] 1 Min #19 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-02-26 18:47:33 CLJ9-NYMEX [CBV] 1 Min #19 | There are no continuous futures contract symbols. Loading data normally. | 2019-02-26 18:47:33 CLJ9-NYMEX [CS] Monthly #8 | Reloading chart. | 2019-02-26 18:47:33 CLJ9-NYMEX [CS] Monthly #8 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-02-26 18:47:33 CLJ9-NYMEX [CS] Monthly #8 | There are no continuous futures contract symbols. Loading data normally. | 2019-02-26 18:47:33 CLH9-NYMEX [CBV] Weekly #9 | Reloading chart. | 2019-02-26 18:47:34 CLH9-NYMEX [CBV] Weekly #9 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-02-26 18:47:34 CLH9-NYMEX [CBV] Weekly #9 | There are no continuous futures contract symbols. Loading data normally. | 2019-02-26 18:47:34 CLJ9-NYMEX [CBV] #2 | Reloading chart. | 2019-02-26 18:47:34 CLJ9-NYMEX [CBV] #2 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-02-26 18:47:34 CLJ9-NYMEX [CBV] #2 | There are no continuous futures contract symbols. Loading data normally. | 2019-02-26 18:47:34 CLJ9-NYMEX [CS] Daily #10 | Reloading chart. | 2019-02-26 18:47:34 CLJ9-NYMEX [CS] Daily #10 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-02-26 18:47:34 CLJ9-NYMEX [CS] Daily #10 | There are no continuous futures contract symbols. Loading data normally. | 2019-02-26 18:47:34 CLJ9-NYMEX [CS] Quarterly #11 | Reloading chart. | 2019-02-26 18:47:34 CLJ9-NYMEX [CS] Quarterly #11 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-02-26 18:47:34 CLJ9-NYMEX [CS] Quarterly #11 | There are no continuous futures contract symbols. Loading data normally. | 2019-02-26 18:47:34 CLJ9-NYMEX [CS] Monthly #12 | Reloading chart. | 2019-02-26 18:47:34 CLJ9-NYMEX [CS] Monthly #12 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-02-26 18:47:34 CLJ9-NYMEX [CS] Monthly #12 | There are no continuous futures contract symbols. Loading data normally. | 2019-02-26 18:47:34 CLJ9-NYMEX [CBV] 15000 Volume #14 | Reloading chart. | 2019-02-26 18:47:34 CLJ9-NYMEX [CBV] 15000 Volume #14 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-02-26 18:47:34 CLJ9-NYMEX [CBV] 15000 Volume #14 | There are no continuous futures contract symbols. Loading data normally. | 2019-02-26 18:47:34 CLJ9-NYMEX [CBV] 0.16 Range #17 | Reloading chart. | 2019-02-26 18:47:34 CLJ9-NYMEX [CBV] 0.16 Range #17 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-02-26 18:47:34 CLJ9-NYMEX [CBV] 0.16 Range #17 | There are no continuous futures contract symbols. Loading data normally. | 2019-02-26 18:47:34 CLJ9-NYMEX [CBV] 2000 Volume #3 | Reloading chart. | 2019-02-26 18:47:34 CLJ9-NYMEX [CBV] 2000 Volume #3 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-02-26 18:47:34 CLJ9-NYMEX [CBV] 2000 Volume #3 | There are no continuous futures contract symbols. Loading data normally. | 2019-02-26 18:47:34 CLJ9-NYMEX [CBV] 2000 Volume #13 | Reloading chart. | 2019-02-26 18:47:34 CLJ9-NYMEX [CBV] 2000 Volume #13 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-02-26 18:47:34 CLJ9-NYMEX [CBV] 2000 Volume #13 | There are no continuous futures contract symbols. Loading data normally. | 2019-02-26 18:47:34 CLJ9-NYMEX [CBV] 1000 Volume #4 | Reloading chart. | 2019-02-26 18:47:34 CLJ9-NYMEX [CBV] 1000 Volume #4 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-02-26 18:47:34 CLJ9-NYMEX [CBV] 1000 Volume #4 | There are no continuous futures contract symbols. Loading data normally. | 2019-02-26 18:47:34 CLJ9-NYMEX 10 Sec #18 | Reloading chart. | 2019-02-26 18:47:34 CLJ9-NYMEX [CBV] 2000 Volume #7 | Reloading chart. | 2019-02-26 18:47:34 CLJ9-NYMEX [CBV] 2000 Volume #7 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-02-26 18:47:34 CLJ9-NYMEX [CBV] 2000 Volume #7 | There are no continuous futures contract symbols. Loading data normally. | 2019-02-26 18:47:34 CLJ9-NYMEX [CBV] #1 | Reloading chart. | 2019-02-26 18:47:35 CLJ9-NYMEX [CBV] #1 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-02-26 18:47:35 CLJ9-NYMEX [CBV] #1 | There are no continuous futures contract symbols. Loading data normally. | 2019-02-26 18:47:35 CLJ9-NYMEX [CBV] #16 | Reloading chart. | 2019-02-26 18:47:35 CLJ9-NYMEX [CBV] #16 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-02-26 18:47:35 CLJ9-NYMEX [CBV] #16 | There are no continuous futures contract symbols. Loading data normally. | 2019-02-26 18:47:35 + Loading market depth data. | 2019-02-26 18:47:35 HTTPS login.sierrachart.com:443 (1) | Socket gracefully closed by remote side. | 2019-02-26 18:47:35 HTTPS www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2019-02-26 18:47:36 HTTPS www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2019-02-26 18:47:36 HTTPS www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2019-02-26 18:47:37 CLJ9-NYMEX [CBV] 1000 Volume #21 | Reloading chart. | 2019-02-26 18:47:42 CLJ9-NYMEX [CBV] 1000 Volume #21 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-02-26 18:47:42 CLJ9-NYMEX [CBV] 1000 Volume #21 | There are no continuous futures contract symbols. Loading data normally. | 2019-02-26 18:47:42 Loaded depth data records for CLJ9-NYMEX 2019-02-21 from 2019-02-21 19:30:00 to 2019-02-21 23:59:59. | 2019-02-26 18:47:42 HTTPS login.sierrachart.com:443 (1) | Max send buffers used during socket life: 1 | 2019-02-26 18:47:42 HTTPS login.sierrachart.com:443 (1) | Signaling to core to close socket | 2019-02-26 18:47:42 HTTPS login.sierrachart.com:443 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-26 18:47:42 HTTPS login.sierrachart.com:443 (1) | Closed. | 2019-02-26 18:47:42 : Array is unallocated. | 2019-02-26 18:47:42 : Array is unallocated. | 2019-02-26 18:47:42 HTTPS www.sierrachart.com:443 (2) | Max send buffers used during socket life: 1 | 2019-02-26 18:47:42 HTTPS www.sierrachart.com:443 (2) | Signaling to core to close socket | 2019-02-26 18:47:42 HTTPS www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-26 18:47:42 HTTPS www.sierrachart.com:443 (2) | Closed. | 2019-02-26 18:47:42 HTTPS www.sierrachart.com:443 (4) | Max send buffers used during socket life: 1 | 2019-02-26 18:47:42 HTTPS www.sierrachart.com:443 (4) | Signaling to core to close socket | 2019-02-26 18:47:42 HTTPS www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-26 18:47:42 HTTPS www.sierrachart.com:443 (4) | Closed. | 2019-02-26 18:47:42 Chart #1 has tagged chart #16 for full recalculation. Chartbook: Tim Master.Cht | 2019-02-26 18:47:43 Chart #1 has tagged chart #16 for full recalculation. Chartbook: Tim Master.Cht | 2019-02-26 18:47:43 HTTPS www.sierrachart.com:443 (5) | Max send buffers used during socket life: 1 | 2019-02-26 18:47:43 HTTPS www.sierrachart.com:443 (5) | Signaling to core to close socket | 2019-02-26 18:47:43 HTTPS www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-26 18:47:43 HTTPS www.sierrachart.com:443 (5) | Closed. | 2019-02-26 18:47:43 CLJ9-NYMEX [CBV-D] 1000 Volume #5 | Reloading chart. | 2019-02-26 18:47:43 CLJ9-NYMEX [CBV-D] 1000 Volume #5 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-02-26 18:47:43 CLJ9-NYMEX [CBV-D] 1000 Volume #5 | There are no continuous futures contract symbols. Loading data normally. | 2019-02-26 18:47:43 CLJ9-NYMEX [CBV-D] 1000 Volume #6 | Reloading chart. | 2019-02-26 18:47:43 CLJ9-NYMEX [CBV-D] 1000 Volume #6 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-02-26 18:47:43 CLJ9-NYMEX [CBV-D] 1000 Volume #6 | There are no continuous futures contract symbols. Loading data normally. | 2019-02-26 18:47:43 CLJ9-NYMEX [CBV-D] 1 Min #19 | Reloading chart. | 2019-02-26 18:47:43 CLJ9-NYMEX [CBV-D] 1 Min #19 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-02-26 18:47:43 CLJ9-NYMEX [CBV-D] 1 Min #19 | There are no continuous futures contract symbols. Loading data normally. | 2019-02-26 18:47:43 CLH9-NYMEX [CBV-D] Weekly #9 | Reloading chart. | 2019-02-26 18:47:43 CLH9-NYMEX [CBV-D] Weekly #9 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-02-26 18:47:43 CLH9-NYMEX [CBV-D] Weekly #9 | There are no continuous futures contract symbols. Loading data normally. | 2019-02-26 18:47:43 Chart #9 has tagged chart #13 for full recalculation. Chartbook: Tim Master.Cht | 2019-02-26 18:47:43 Chart #9 has tagged chart #14 for full recalculation. Chartbook: Tim Master.Cht | 2019-02-26 18:47:43 Chart #9 has tagged chart #16 for full recalculation. Chartbook: Tim Master.Cht | 2019-02-26 18:47:43 Chart #9 has tagged chart #19 for full recalculation. Chartbook: Tim Master.Cht | 2019-02-26 18:47:43 Chart #9 has tagged chart #3 for full recalculation. Chartbook: Tim Master.Cht | 2019-02-26 18:47:43 Chart #9 has tagged chart #7 for full recalculation. Chartbook: Tim Master.Cht | 2019-02-26 18:47:43 Chart #9 has tagged chart #13 for full recalculation. Chartbook: Tim Master.Cht | 2019-02-26 18:47:43 Chart #9 has tagged chart #14 for full recalculation. Chartbook: Tim Master.Cht | 2019-02-26 18:47:43 Chart #9 has tagged chart #16 for full recalculation. Chartbook: Tim Master.Cht | 2019-02-26 18:47:43 Chart #9 has tagged chart #19 for full recalculation. Chartbook: Tim Master.Cht | 2019-02-26 18:47:43 Chart #9 has tagged chart #3 for full recalculation. Chartbook: Tim Master.Cht | 2019-02-26 18:47:43 Chart #9 has tagged chart #7 for full recalculation. Chartbook: Tim Master.Cht | 2019-02-26 18:47:43 CLJ9-NYMEX [CBV-D] 15000 Volume #14 | Reloading chart. | 2019-02-26 18:47:43 CLJ9-NYMEX [CBV-D] 15000 Volume #14 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-02-26 18:47:43 CLJ9-NYMEX [CBV-D] 15000 Volume #14 | There are no continuous futures contract symbols. Loading data normally. | 2019-02-26 18:47:43 CLJ9-NYMEX [CBV-D] 0.16 Range #17 | Reloading chart. | 2019-02-26 18:47:43 CLJ9-NYMEX [CBV-D] 0.16 Range #17 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-02-26 18:47:43 CLJ9-NYMEX [CBV-D] 0.16 Range #17 | There are no continuous futures contract symbols. Loading data normally. | 2019-02-26 18:47:43 CLJ9-NYMEX [CBV-D] 2000 Volume #3 | Reloading chart. | 2019-02-26 18:47:43 CLJ9-NYMEX [CBV-D] 2000 Volume #3 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-02-26 18:47:43 CLJ9-NYMEX [CBV-D] 2000 Volume #3 | There are no continuous futures contract symbols. Loading data normally. | 2019-02-26 18:47:43 CLJ9-NYMEX [CBV-D] 2000 Volume #13 | Reloading chart. | 2019-02-26 18:47:43 CLJ9-NYMEX [CBV-D] 2000 Volume #13 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-02-26 18:47:43 CLJ9-NYMEX [CBV-D] 2000 Volume #13 | There are no continuous futures contract symbols. Loading data normally. | 2019-02-26 18:47:43 CLJ9-NYMEX [CBV-D] 1000 Volume #4 | Reloading chart. | 2019-02-26 18:47:43 CLJ9-NYMEX [CBV-D] 1000 Volume #4 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-02-26 18:47:43 CLJ9-NYMEX [CBV-D] 1000 Volume #4 | There are no continuous futures contract symbols. Loading data normally. | 2019-02-26 18:47:43 CLJ9-NYMEX [CS-D] Daily #10 | Reloading chart. | 2019-02-26 18:47:43 CLJ9-NYMEX [CS-D] Daily #10 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-02-26 18:47:43 CLJ9-NYMEX [CS-D] Daily #10 | There are no continuous futures contract symbols. Loading data normally. | 2019-02-26 18:47:43 CLJ9-NYMEX [CS-D] Monthly #8 | Reloading chart. | 2019-02-26 18:47:43 CLJ9-NYMEX [CS-D] Monthly #8 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-02-26 18:47:43 CLJ9-NYMEX [CS-D] Monthly #8 | There are no continuous futures contract symbols. Loading data normally. | 2019-02-26 18:47:43 CLJ9-NYMEX [CBV-D] 2000 Volume #7 | Reloading chart. | 2019-02-26 18:47:43 CLJ9-NYMEX [CBV-D] 2000 Volume #7 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-02-26 18:47:43 CLJ9-NYMEX [CBV-D] 2000 Volume #7 | There are no continuous futures contract symbols. Loading data normally. | 2019-02-26 18:47:43 Loaded depth data records for CLJ9-NYMEX 2019-02-22 from 2019-02-22 00:00:00 to 2019-02-22 17:27:32. | 2019-02-26 18:47:44 Chart #8 has tagged chart #7 for full recalculation. Chartbook: Tim Master.Cht | 2019-02-26 18:47:44 Chart #8 has tagged chart #7 for full recalculation. Chartbook: Tim Master.Cht | 2019-02-26 18:47:44 Chart #6 has tagged chart #13 for full recalculation. Chartbook: Tim Master.Cht | 2019-02-26 18:47:45 Chart #6 has tagged chart #16 for full recalculation. Chartbook: Tim Master.Cht | 2019-02-26 18:47:45 Chart #6 has tagged chart #19 for full recalculation. Chartbook: Tim Master.Cht | 2019-02-26 18:47:45 Chart #6 has tagged chart #3 for full recalculation. Chartbook: Tim Master.Cht | 2019-02-26 18:47:45 Chart #6 has tagged chart #7 for full recalculation. Chartbook: Tim Master.Cht | 2019-02-26 18:47:45 Chart #6 has tagged chart #13 for full recalculation. Chartbook: Tim Master.Cht | 2019-02-26 18:47:45 Chart #6 has tagged chart #16 for full recalculation. Chartbook: Tim Master.Cht | 2019-02-26 18:47:45 Chart #6 has tagged chart #19 for full recalculation. Chartbook: Tim Master.Cht | 2019-02-26 18:47:45 Chart #6 has tagged chart #3 for full recalculation. Chartbook: Tim Master.Cht | 2019-02-26 18:47:45 Chart #6 has tagged chart #7 for full recalculation. Chartbook: Tim Master.Cht | 2019-02-26 18:47:45 Chart #5 has tagged chart #13 for full recalculation. Chartbook: Tim Master.Cht | 2019-02-26 18:47:45 Chart #5 has tagged chart #16 for full recalculation. Chartbook: Tim Master.Cht | 2019-02-26 18:47:45 Chart #5 has tagged chart #19 for full recalculation. Chartbook: Tim Master.Cht | 2019-02-26 18:47:45 Chart #5 has tagged chart #3 for full recalculation. Chartbook: Tim Master.Cht | 2019-02-26 18:47:45 Chart #5 has tagged chart #7 for full recalculation. Chartbook: Tim Master.Cht | 2019-02-26 18:47:45 Chart #5 has tagged chart #13 for full recalculation. Chartbook: Tim Master.Cht | 2019-02-26 18:47:45 Chart #5 has tagged chart #16 for full recalculation. Chartbook: Tim Master.Cht | 2019-02-26 18:47:45 Chart #5 has tagged chart #19 for full recalculation. Chartbook: Tim Master.Cht | 2019-02-26 18:47:45 Chart #5 has tagged chart #3 for full recalculation. Chartbook: Tim Master.Cht | 2019-02-26 18:47:45 Chart #5 has tagged chart #7 for full recalculation. Chartbook: Tim Master.Cht | 2019-02-26 18:47:45 CLJ9-NYMEX [CBV-D] #16 | Performing a full recalculation because it has been tagged. Chartbook: Tim Master.Cht | 2019-02-26 18:47:45 CLJ9-NYMEX [CS-D] Monthly #12 | Reloading chart. | 2019-02-26 18:47:45 CLJ9-NYMEX [CS-D] Monthly #12 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-02-26 18:47:45 CLJ9-NYMEX [CS-D] Monthly #12 | There are no continuous futures contract symbols. Loading data normally. | 2019-02-26 18:47:45 CLJ9-NYMEX [CBV-D] 1000 Volume #21 | Reloading chart. | 2019-02-26 18:47:45 CLJ9-NYMEX [CBV-D] 1000 Volume #21 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-02-26 18:47:45 CLJ9-NYMEX [CBV-D] 1000 Volume #21 | There are no continuous futures contract symbols. Loading data normally. | 2019-02-26 18:47:45 Loaded depth data records for CLJ9-NYMEX 2019-02-25 from 2019-02-25 11:35:21 to 2019-02-25 19:13:25. | 2019-02-26 18:47:45 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-26 18:47:45 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-26 18:47:45 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-26 18:47:45 Loaded depth data records for CLJ9-NYMEX 2019-02-26 from 2019-02-26 09:42:34 to 2019-02-26 16:17:56. | 2019-02-26 18:47:45 CLJ9-NYMEX 10 Sec #18 | Reloading chart. | 2019-02-26 18:47:46 CQG FIX: Sending the Logon message. | 2019-02-26 18:47:46 + Loading market depth data. | 2019-02-26 18:47:46 CQG FIX: Received a Logout message. Text = Username or password is incorrect. | 2019-02-26 18:47:46 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2019-02-26 18:47:46 CQG FIX socket (1) | Max send buffers used during socket life: 1 | 2019-02-26 18:47:46 CQG FIX socket (1) | Signaling to core to close socket | 2019-02-26 18:47:46 CQG FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-02-26 18:47:46 CQG FIX Trading | Disconnected. | 2019-02-26 18:47:46 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-26 18:47:46 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-26 18:47:46 CQG FIX socket (1) | Write has completed. Shutdown being performed. | 2019-02-26 18:47:46 CQG FIX socket (1) | Shutdown started. Waiting for graceful close. | 2019-02-26 18:47:46 CQG FIX Trading | Disconnected. | 2019-02-26 18:47:46 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-26 18:47:46 CQG FIX socket (1) | Socket gracefully closed by remote side. | 2019-02-26 18:47:46 CQG FIX socket (1) | Closed. | 2019-02-26 18:47:46 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-26 18:47:49 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-26 18:47:49 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-26 18:47:49 CQG FIX: Sending the Logon message. | 2019-02-26 18:47:50 CQG FIX: Received a Logout message. Text = Username or password is incorrect. | 2019-02-26 18:47:51 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2019-02-26 18:47:51 CQG FIX socket (1) | Max send buffers used during socket life: 1 | 2019-02-26 18:47:51 CQG FIX socket (1) | Signaling to core to close socket | 2019-02-26 18:47:51 CQG FIX Trading | Disconnected. | 2019-02-26 18:47:51 CQG FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-02-26 18:47:51 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-26 18:47:51 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-26 18:47:51 CQG FIX socket (1) | Write has completed. Shutdown being performed. | 2019-02-26 18:47:51 CQG FIX socket (1) | Shutdown started. Waiting for graceful close. | 2019-02-26 18:47:51 CQG FIX Trading | Disconnected. | 2019-02-26 18:47:51 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-26 18:47:51 CQG FIX socket (1) | Socket gracefully closed by remote side. | 2019-02-26 18:47:51 CQG FIX socket (1) | Closed. | 2019-02-26 18:47:51 Loaded depth data records for CLJ9-NYMEX 2019-02-21 from 2019-02-21 19:30:00 to 2019-02-21 23:59:59. | 2019-02-26 18:47:53 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-26 18:47:54 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-26 18:47:54 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-26 18:47:54 Loaded depth data records for CLJ9-NYMEX 2019-02-22 from 2019-02-22 00:00:00 to 2019-02-22 17:27:32. | 2019-02-26 18:47:54 CQG FIX: Sending the Logon message. | 2019-02-26 18:47:54 Loaded depth data records for CLJ9-NYMEX 2019-02-25 from 2019-02-25 11:35:21 to 2019-02-25 19:13:25. | 2019-02-26 18:47:55 CQG FIX: Received a Logout message. Text = Username or password is incorrect. | 2019-02-26 18:47:55 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2019-02-26 18:47:55 CQG FIX socket (1) | Max send buffers used during socket life: 1 | 2019-02-26 18:47:55 CQG FIX socket (1) | Signaling to core to close socket | 2019-02-26 18:47:55 CQG FIX Trading | Disconnected. | 2019-02-26 18:47:55 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-26 18:47:55 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-26 18:47:55 CQG FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-02-26 18:47:55 CQG FIX socket (1) | Write has completed. Shutdown being performed. | 2019-02-26 18:47:55 CQG FIX socket (1) | Shutdown started. Waiting for graceful close. | 2019-02-26 18:47:55 CQG FIX Trading | Disconnected. | 2019-02-26 18:47:55 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-26 18:47:55 CQG FIX socket (1) | Socket gracefully closed by remote side. | 2019-02-26 18:47:55 CQG FIX socket (1) | Closed. | 2019-02-26 18:47:55 Loaded depth data records for CLJ9-NYMEX 2019-02-26 from 2019-02-26 09:42:34 to 2019-02-26 16:17:56. | 2019-02-26 18:47:55 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-26 18:47:58 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-26 18:47:58 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-26 18:47:58 CQG FIX: Sending the Logon message. | 2019-02-26 18:47:59 CQG FIX: Received a Logout message. Text = Username or password is incorrect. | 2019-02-26 18:47:59 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2019-02-26 18:47:59 CQG FIX socket (1) | Max send buffers used during socket life: 1 | 2019-02-26 18:47:59 CQG FIX socket (1) | Signaling to core to close socket | 2019-02-26 18:47:59 CQG FIX Trading | Disconnected. | 2019-02-26 18:47:59 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-26 18:47:59 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-26 18:47:59 CQG FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-02-26 18:47:59 CQG FIX socket (1) | Write has completed. Shutdown being performed. | 2019-02-26 18:47:59 CQG FIX socket (1) | Shutdown started. Waiting for graceful close. | 2019-02-26 18:47:59 CQG FIX Trading | Disconnected. | 2019-02-26 18:47:59 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-26 18:47:59 CQG FIX socket (1) | Socket gracefully closed by remote side. | 2019-02-26 18:48:00 CQG FIX socket (1) | Closed. | 2019-02-26 18:48:00 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-26 18:48:03 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-26 18:48:03 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-26 18:48:03 CQG FIX: Sending the Logon message. | 2019-02-26 18:48:03 CQG FIX: Received a Logout message. Text = Username or password is incorrect. | 2019-02-26 18:48:05 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2019-02-26 18:48:05 CQG FIX socket (1) | Max send buffers used during socket life: 1 | 2019-02-26 18:48:05 CQG FIX socket (1) | Signaling to core to close socket | 2019-02-26 18:48:05 CQG FIX Trading | Disconnected. | 2019-02-26 18:48:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-26 18:48:05 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-26 18:48:05 CQG FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-02-26 18:48:05 CQG FIX socket (1) | Write has completed. Shutdown being performed. | 2019-02-26 18:48:05 CQG FIX socket (1) | Shutdown started. Waiting for graceful close. | 2019-02-26 18:48:05 CQG FIX Trading | Disconnected. | 2019-02-26 18:48:05 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-26 18:48:05 CQG FIX socket (1) | Socket gracefully closed by remote side. | 2019-02-26 18:48:05 CQG FIX socket (1) | Closed. | 2019-02-26 18:48:05 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-26 18:48:08 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-26 18:48:08 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-26 18:48:08 CQG FIX: Sending the Logon message. | 2019-02-26 18:48:09 CQG FIX: Received a Logout message. Text = Too many failed logon attempts. Contact your FCM. | 2019-02-26 18:48:09 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2019-02-26 18:48:09 CQG FIX socket (1) | Max send buffers used during socket life: 1 | 2019-02-26 18:48:09 CQG FIX socket (1) | Signaling to core to close socket | 2019-02-26 18:48:09 CQG FIX Trading | Disconnected. | 2019-02-26 18:48:09 CQG FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-02-26 18:48:09 CQG FIX Trading | Disconnected. | 2019-02-26 18:48:09 CQG FIX socket (1) | Write has completed. Shutdown being performed. | 2019-02-26 18:48:09 CQG FIX socket (1) | Shutdown started. Waiting for graceful close. | 2019-02-26 18:48:09 CQG FIX socket (1) | Socket gracefully closed by remote side. | 2019-02-26 18:48:09 CQG FIX socket (1) | Closed. | 2019-02-26 18:48:09 |
[2019-02-26 19:09:13] |
This is the relevant message: CQG FIX: Received a Logout message. Text = Username or password is incorrect. | 2019-02-26 18:47:55 Refer to item 4 here: CQG Trading Platform Service: Common Error Messages Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-26 19:12:03
