Date/Time: Sun, 19 May 2024 23:56:49 +0000
Different number bars data
View Count: 713
[2019-02-26 07:23:37] |
Dom7364 - Posts: 257 |
Why the different data in both attached charts? Not sure why that is, everything is the same.. Thanks |
F.US.EU6H19 [CV] 1 Day #5 2019-02-26 07_20_50.839.png / V - Attached On 2019-02-26 07:21:10 UTC - Size: 127.73 KB - 267 views F.US.EU6H19 [C] 1 Day #5 2019-02-26 07_21_27.067.png / V - Attached On 2019-02-26 07:21:43 UTC - Size: 87.15 KB - 243 views |
[2019-02-26 10:57:44] |
And what exactly is meant by everything is the same? That could not be the case. Check the Chart Settings.
[2019-02-26 14:04:50] |
Same contract, same times, same sesions, why should it no be the same?? 2 daily chart, exactly same parameters, same contract, same period, completely different data, so wondering how/why? Date Time Of Last Edit: 2019-02-26 17:44:56
[2019-02-26 19:38:35] |
Check these settings: Chart Settings: Volume at Price Multiplier for Historical/Intraday Chart (Chart >> Chart Settings >> Chart Data >> Volume at Price menu) Chart Settings: Tick Size (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
