Date/Time: Tue, 07 May 2024 22:06:28 +0000
Volume Value Area Lines Alert
View Count: 881
[2019-02-26 05:16:26] |
mocazteam - Posts: 2 |
How to make Alert if the POC line change in Volume Value Area Line indicator Thnks Date Time Of Last Edit: 2019-02-26 05:17:05
Screenshot_1.png / V - Attached On 2019-02-26 05:16:02 UTC - Size: 33.66 KB - 346 views |
[2019-03-07 02:34:21] |
Any help
[2019-03-07 16:42:45] |
John - SC Support - Posts: 31441 |
You just have to compare the current bar against the last one. The alert condition would look like the following: = ID1.SG1[0] <> ID1.SG1[-1] Refer to the following for how to reference the chart bars in an Alert: Study/Chart Alerts And Scanning: Referencing Data Other Than on the Last Bar/Column In the Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-03-13 23:48:41] |
Here is the relevant documentation for entering an alert formula on a study: Study/Chart Alerts And Scanning: To Enter an Alert Condition on a Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
