Date/Time: Sun, 19 May 2024 11:19:45 +0000
Hotkey
View Count: 1094
[2019-02-24 22:52:47] |
User34124 - Posts: 271 |
Hi thanks for this new feature, been waiting many years for it, so handy. Under 'Customize Keyboard shortcuts', there seems to be nothing under 'Selected Command' like there is with other features.. hence users cannot assign a keyboard to it. Just thought I'd make you aware. Thanks. Also as we are on the topic, how does one arrange the files in the chartbook group folder so they can open in a desired order? the default is alphabetical, which makes it difficult to say open EURUSD, EURJPY, EURGBP in that order. Instead you must add a,b,c or 1,2,3 infront of them, in which case you may run out after 26 or 9 characters (as typing 11 will make it go to the second order ie after 1), and get very confusing Date Time Of Last Edit: 2019-02-24 23:03:48
[2019-02-26 00:31:10] |
To customize Keyboard shortcuts, refer to the documentation here: Global Settings Menu: Customize Keyboard Shortcuts (Global Settings menu) Also this is not a new feature. So we are not sure what feature you are referring to. The ordering of Chartbooks in a Chartbook Group is alphabetical. It cannot be changed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-02-27 17:19:22] |
Please try to assign a hotkey to File >> Open Chartbook Group, and you will see it does not work. That is all
[2019-03-02 08:29:21] |
This will be supported in the next release.
