Date/Time: Fri, 03 May 2024 23:01:16 +0000
Zigzag study outputs spurious data to spreadsheet studies in recent versions
View Count: 1418
[2013-11-14 23:47:39] |
Sawtooth - Posts: 3993 |
I have built several custom spreadsheet studies based on the Zigzag study. They work correctly in v1032 and earlier, but do not in v1046. In v1046, the Text Labels, Reversal Price, ZZ Length, ZZ num Bars columns contain spurious outputs not associated with ZZ line reversals. And some line reversals do not contain any outputs. I use these outputs in formulas. This only occurs in Replay or live as the lines are built. See attached pics. I have a test chartbook if you need it. |
ZZ test v1032.PNG / V - Attached On 2013-11-14 23:46:42 UTC - Size: 74.1 KB - 467 views ZZ test v1046.png / V - Attached On 2013-11-14 23:46:52 UTC - Size: 86.01 KB - 455 views |
[2013-11-15 21:31:50] |
apollofl - Posts: 95 |
Hey Tom I see no answer or response...yet.
[2013-11-15 22:03:04] |
We plan to solve this today.
[2013-11-17 02:43:24] |
Fixed.
[2013-11-17 10:35:13] |
How is it Fixed, is there a new version of SC to download?
[2013-11-17 11:09:59] |
Not yet.
[2013-11-18 12:53:30] |
Thank You Support...Well Done
