Date/Time: Mon, 20 May 2024 00:18:02 +0000
Rithmic data issue on sub instance using 1877
View Count: 700
[2019-02-21 13:01:43] |
samual sprat - Posts: 343 |
Hi, after updating to 1877 when i run a sub instance, the main instance crashes and becomes unresponsive. Can't get the error log from the main instance for this as it's crashed. I don't have any chart loaded. After reverting to 1875 it's working fine Thanks S |
[2019-02-22 01:42:09] |
We cannot reproduce this issue. Do you notice any problem when you have set Global Settings >> Data/Trade Service Settings >> Service to SC Data-All Services in the main instance and in the sub instance using a symbol like EURUSD?
[2019-02-27 04:12:23] |
We have resolved this problem. It is resolved in prerelease 1880.
