Date/Time: Sat, 18 May 2024 18:26:36 +0000
Moving time line sequence
View Count: 493
[2019-02-21 04:08:20] |
Willson - Posts: 176 |
My systems rely on viewing vertical time lines aligned with certain events. So if time lines are set to 5 min between lines, I wish to use pointer to move the sequence of lines to align with a certain event. I am not attempting to vary the time between lines. I want to adjust all 5 min lines forward or backward until one of the lines align with an event. Want to do this using pointer. This may now be possible, can't find a method.Help appreciated.
[2019-02-21 05:47:22] |
Have a look at the Time Expansion or the Time Projection drawing tools to see if you can accomplish what you want. You can then easily move those drawings.
