Date/Time: Sat, 18 May 2024 22:45:43 +0000
Updating from Older Version Issue
View Count: 564
[2019-02-20 14:49:14] |
arrow - Posts: 52 |
Hey guys I updated to the latest version 1875 from a 15** version. I got all my charts setup again but my data is not updating correctly and the DOM on chart is not working. I run 2 PC's the second one is running version 1669 and is working fine. When I disconnect and reconnect the data feed on PC1 it loads data about 10 or 15 min behind current time and continues to fall further behind I've also tried shutting down PC2 and only using a single instance on PC1 still get the same thing. I was running both PC's with no issues before I updated PC1 to 1875. Date Time Of Last Edit: 2019-02-21 05:32:17
[2019-02-21 05:31:44] |
It sounds like one of the problems you had was with opening your older version Chartbook. In regards to this, refer to the notes for 1877 here: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer1877 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-21 05:32:07
