Date/Time: Sat, 18 May 2024 21:06:08 +0000
TPO profile versus Candlestick TPO Value difference
View Count: 666
[2019-02-20 11:38:51] |
User661434 - Posts: 27 |
I have a question regarding TPO that I can't solve: I want to set a daily POC value in candlesticks so I am using the value lines study. I use a 12H candlestick with the 1440 min = 1 day for the tpo block) and I compare this with the classic daily TPO chart but I get difference values. How can I adjust this that I get the same values in the candlesticks of the daily TPO, pls see the settings for both study's in attach Thanks for your help |
Attachment Deleted. Private File |
[2019-02-20 23:05:20] |
There definitely is not going to be a match because the Price Increment in Ticks and TPO Letter Time Period Length Inputs are different between the two instances of the studies. Also it does not make sense to be using 1440 minutes for TPO Letter Time Period Length and have the overall period at 1 day. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
