Date/Time: Sat, 18 May 2024 20:37:00 +0000
Customise Chart Drawing Menu
View Count: 580
[2019-02-20 09:28:45] |
samual sprat - Posts: 343 |
Hi, Under the 'Customise Chart Drawing Menu' there is the option to 'Extend Drawing'. This is very useful. Is it possible to add 'Un-Extend Drawing' also please? This would make it much simpler to switch back Also is is possible to add 'Extend Drawing'and 'Un-Extend Drawing' to keyboard shortcuts? Thanks, S Date Time Of Last Edit: 2019-02-20 09:46:00
[2019-02-21 00:46:24] |
For this you need to use the Cut Drawing command.
[2019-02-21 11:30:17] |
OMG that's amazing. It even works on Ray tool. Thanks!
