Date/Time: Wed, 01 May 2024 21:46:02 +0000
Possible to copy a study over to new chart with custom settings.
View Count: 1995
[2019-02-20 06:17:55] |
User541156 - Posts: 67 |
I know we can save the study collection and reapply on a brand new chart, or just clone the chart and add/remove any study we want. But is it possible to somehow save settings of a single study i.e. Daily OHLC with certain colors and line widths on Chart # 1 and then add that just that 1 study (Daily OHLC) to a different Chart # 2 without applying a complete study collection? Because Chart # 2 might already have different indicators on it which I dont want to disturb and all I need is to not re-do all the settings of Daily OHLC again. Thanks. |
[2019-02-21 09:05:39] |
What you can do is create a Study Collection consisting of a single study and then use the option to Prompt to Remove Existing Studies and then when applying it to the other chart, do not remove the existing studies.
[2019-02-21 11:22:48] |
That would do perfectly.
Date Time Of Last Edit: 2019-02-21 11:24:13
[2022-10-05 13:04:55] |
User132988 - Posts: 13 |
Be great if you just had a load option to load previously saved studies...
