Date/Time: Sat, 18 May 2024 20:44:10 +0000
New to Sierra Charts question about Stock Exchange Data
View Count: 678
[2019-02-19 16:57:20] |
CFC - Posts: 9 |
Hi, I can pay for Sierra Charts through my Futures Broker. I also want tick data for NYSE and Nasdaq stocks which I cannot access through the Futures broker. Can anyone recommend a good data provider which will be compatible with Sierra Charts.
[2019-02-19 23:00:47] |
You just need to use your own direct account: Direct Sierra Chart Account And then you can use the Sierra Chart Historical Data service for this data if you just require historical data: Sierra Chart Historical Data Service If you need real-time data, you need to use this service instead: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-02-20 14:09:00] |
CFC - Posts: 9 |
Thanks for the info. Is it possible for me to pay for Sierra Charts Package 5 directly from Sierra Charts so I have the full version and get my futures data from CQG via my futures broker and also subscribe to the U.S Equities package $10.50 a month from Sierra charts, then I would have all the futures and stock data I would need. Please let me know if this combination is possible
[2019-02-21 00:35:04] |
Yes you can do that but understand this is the pricing for the stock data feed: Sierra Chart Exchange Data Feed: Data Feed Pricing (Pricing) There is also the cost of the real-time data connection. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-21 00:35:13
[2019-02-21 09:06:52] |
CFC - Posts: 9 |
Ok Great, if I am getting my futures data from CQG and U.S equity data from Sierra Charts. Is it possible to look at both the futures and stock data at the same time. Or is it only possible to look at futures or stock data because you have to configure in the settings what data provider you are using.
Date Time Of Last Edit: 2019-02-21 09:18:18
[2019-02-21 10:13:51] |
Yes both can be looked at, at the same time in the instance of Sierra Chart connected to CQG.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-21 10:14:06
[2019-02-21 10:21:11] |
CFC - Posts: 9 |
Ok great, just got one more question regarding the fees for the U.S equity data. The monthly fee for Sierra Charts package 5 is $36.00, plus $10.50 for U.S equity exchange fee and $25.00 for 20 symbols, is there any other fee's on top of these?
[2019-02-21 18:31:44] |
No, this is all.
[2019-02-21 19:00:48] |
CFC - Posts: 9 |
Ok Thanks
