Date/Time: Sun, 28 Apr 2024 02:40:32 +0000
[User Discussion] - Volume Value Area Lines time period issue
View Count: 677
[2019-02-15 23:04:31] |
Devil_On_WallStreet - Posts: 67 |
I am using the Volume Value Area Lines indicator set at 60 minutes as the interval with the option of New Period at Day session start... So it starts at 9:30 ET... which SHOULD mean that the next period will start at 10:30 ET... HOWEVER, this is not the case... it begins it's next period at 10:00 ET (30 minutes) and continues to change periods every hour on the hour. The option I selected is NOT hourly(which isn't even an option) Selecting a period of 60 minutes, should change every 60 minutes from the day start...
[2019-02-16 16:56:40] |
User16876 - Posts: 10 |
Do you have a Session Start Time in Chart settings set to 9:30:00 as well?
SessionStart.jpg / V - Attached On 2019-02-16 16:53:13 UTC - Size: 115.48 KB - 293 views |
[2019-02-17 01:06:36] |
YES!!! Well I use Chicago time so my chart says 8:30... I'm attaching some Jpegs... first are the study settings, 2nd shows the session start @ 8:30... 3rd shows the Volume Value Area Lines shifting @ 9:00 after only 30 minutes.
settings.JPG / V - Attached On 2019-02-17 01:04:05 UTC - Size: 48.8 KB - 289 views sess_start.JPG / V - Attached On 2019-02-17 01:04:54 UTC - Size: 168.35 KB - 285 views |
[2019-02-17 01:38:40] |
also to add... it doesn't matter whether I set the reference periods back at either 0 or 1....
