Date/Time: Fri, 03 May 2024 01:46:01 +0000
bid ask
View Count: 630
[2019-02-15 20:21:51] |
arruga - Posts: 249 |
is there a way to select which price to show on the price axis and which prices to build the chart bars with? whether ask price, bid price, ask/bid average, last price? which is the default actually shown if haven't set up anything?
[2019-02-16 16:46:44] |
Yes this is fully supported. Refer to: Data Recording Modes The default depends upon the symbol especially if you are using Interactive Brokers. But in general it is the last trade price Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-16 16:47:42
