Date/Time: Thu, 02 May 2024 12:52:49 +0000
[Programming Help] - Type Text encoding
View Count: 724
[2019-02-15 06:38:18] |
User403598 - Posts: 15 |
This bug haven't a big significance, but it's my duty to inform you: Type text tool broken encoding (cyrillic on screenshot) |
2019-02-15_10-28-11.png / V - Attached On 2019-02-15 06:37:36 UTC - Size: 13.88 KB - 272 views |
[2019-02-15 17:53:18] |
Yes we are aware of this. We need to support Unicode in Sierra Chart and that is going to be done as soon as we can. Not likely until towards the end of the year. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-02-16 00:19:49] |
User972768 - Posts: 166 |
Great! Would you add that throughout the application or in some specific areas only? I tried to use Greek letters in chart title and didn't get expected result. Thanks |
[2019-02-19 05:15:10] |
It will be throughout.
[2019-06-24 17:07:14] |
SviCh - Posts: 40 |
Until one of recent updates I could use fix from Ganz (selecting font Roman with OEM/DOS), but it is no longer possible
