Date/Time: Mon, 29 Apr 2024 08:24:21 +0000
Chart Tools Value Windows
View Count: 644
[2019-02-14 21:39:26] |
User509820 - Posts: 69 |
Hi, is it possible to have more than one tools value window up? I have multiple monitors I would like one for each new instance. Thanks
[2019-02-15 06:50:59] |
You can by using multiple instances of Sierra Chart, where each one has its own separate values windows: Using DTC Server for Data and Trading in Another Sierra Chart Instance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-15 06:51:24
