Date/Time: Sat, 04 May 2024 03:24:36 +0000
Backing Up Files
View Count: 1117
[2019-02-14 15:25:53] |
User940772 - Posts: 72 |
Hi, I am looking to backup my chartbooks, saved studies, and anything else you believe would be pertinent, in case of a catastrophic hard drive failure. Therefore I was hoping you could suggest the files I need to copy to get this done. Thanks |
[2019-02-14 19:47:35] |
Refer to this help topic: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
