Date/Time: Sat, 04 May 2024 19:42:30 +0000
Study Numbers Bars and numbers bars calculate values disappeared
View Count: 913
[2019-02-14 15:24:38] |
Hopeman - Posts: 156 |
Hello the study of Numbers bars to disappeared and the numbers calculkate values bar can not make any calculation, I do not know why this happened. yesterday everything worked perfect !! Many thanks in advance https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=26007 |
[2019-02-14 16:25:35] |
You need to change to the Advanced service package 5 to use these particular studies. Follow the instructions below. To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation You will need to login if you are not currently logged in. In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button. The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-14 16:25:57
[2019-02-14 17:00:29] |
how is it possible? I was using number bars study yesterday where is the error ? I can not use volume profile either |
[2019-02-14 19:20:17] |
Perhaps you had a trial of the Advanced service package that then expired.
