Date/Time: Sun, 28 Apr 2024 12:51:59 +0000
net advances/declines
View Count: 1468
[2019-02-13 18:18:51] |
User28682 - Posts: 233 |
Hi young man/woman, I would like to graph net of advances/declines on the nyse, starting from the open on an intra day chart. I tried this: symbol 1 = ADV-NYSE symbol 2 = DECL-NYSE then add cumulative sum of study? I got a line that wasn't correct? |
[2019-02-13 18:30:05] |
Use the Study Subgraphs Subtract/Difference study first, then use the Cumulative Sum of Study on the difference study. You will find the documentation for these studies here: Study Subgraphs Subtract/Difference and here: Cumulative Sum of Study Keep in mind that you can always hide the Study Subgraphs Subtract if you do not want to see that information displayed. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-02-13 20:04:14] |
Steps: 1)load ADV-NYSE 2)add additional symbol study DECL-NYSE 3)add study subgraphs difference 4) add cumulative sum of study...reference the study subgraphs difference, reset at start of day = yes. I dont get any line at all? |
[2019-02-13 21:10:59] |
What you want to use is the Advance Decline Line study on the symbol which is documented with the study: Advance Decline Line
