Date/Time: Mon, 06 May 2024 09:28:28 +0000
Draw Style Scroll Bar on Study Settings Subgraphs: Does not Function
View Count: 468
[2019-02-13 15:55:36] |
User73463 - Posts: 21 |
Draw Style Scroll Bar on Study Settings Subgraphs: Does not Function. Once my mouse moves to scroll at the Bar the menu disappears to the draw style that the mouse covered while crossing to use the scroll bar. The only way to function is to move mouse to top or bottom of menu for moving to different style. Version 1873 and previous.
[2019-02-13 16:38:43] |
That list box is provided by the Windows operating system. So what you are seeing is Windows operating system behavior. It is not anything we can control.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-13 16:39:04
