Date/Time: Mon, 06 May 2024 02:39:17 +0000
Sensitivity of Peaks & Vallyes of VbP for TPO not working
View Count: 1433
[2019-02-13 10:03:24] |
Zosimus - Posts: 345 |
Hi SC team, As you can see in the attached images (one with a sensitivity of 1 and one with a sensitivity of 30) the sensitivity setting of the peaks and valleys of Volume profiles for TPO charts is not working (the charts show the same density of peaks and valleys with sensitivity 1 and with sensitivity 30). |
Sensitivity_1.png / V - Attached On 2019-02-13 10:01:50 UTC - Size: 256.41 KB - 253 views Sensitivity_30.png / V - Attached On 2019-02-13 10:02:03 UTC - Size: 307.17 KB - 243 views |
[2019-02-13 15:00:00] |
In the case of a Volume by Price study on a TPO Profile chart, the sensitivity is always controlled by the TPO Profile chart Peak and Valley Sensitivity input. The Peak and Valley Sensitivity Input with the Volume by Price study in this case is ignored.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-13 15:00:36
