Date/Time: Fri, 26 Apr 2024 11:03:38 +0000
Can Sierra Chart Forex Data Be Used To Power 3rd Party Software
View Count: 1294
[2013-11-14 04:55:09] |
User29662 - Posts: 76 |
I am in the process of switching over from NinjaTrader to SierraChart for some of my trading. So far I like SierraChart very much. It will take me a lot of time, however, to convert all my custom NinjaTrader indicators to SierraChart. As such, I currently have to keep both SierraChart and NinjaTrader open. SierraChart is using my broker data (IB), while Ninja is using Kinetick fx data, which is from FXCM, the same source that Sierra gets its fx data. I was wondering if there was any way I could just power my NinjaTrader charts with the SierraChart fx data so I could stop paying for it twice as I am already paying for the same data through Kinetick. Thanks!
[2013-11-14 20:29:00] |
Thank you for your interest in Sierra Chart. There is not a practical way that you can use the Sierra Chart data feeds from another program.
