Date/Time: Mon, 29 Apr 2024 18:50:13 +0000
BROKER CANT HELP! Micro Futures not plotting correctly
View Count: 533
[2019-02-12 15:04:45] |
User951413 - Posts: 12 |
Why is it that the micro futures wont plot correctly? Is there a setting that needs to be adjusted? I compare it to the standard size and the ask and bid lines of the micro are in line with the standard size, however the plotting of bars and the current price lag. This makes it impossible for me to plan my trades. I tried talking to AMP but they have no solution. All they said was" its just the way it is" blaming volume. If it were volume then why do the ask and bid line on both charts match. Its only the plotting of bars, and the current price line that lag. I see it as a graphical issue. Please help. Also according to AMP everyone complains about this, but they cant help. They don't have a solution. Tom Date Time Of Last Edit: 2019-02-12 15:05:23
[2019-02-12 18:07:47] |
What the broker said is completely correct. The solution is to open a chart for the standard size contract and then use the micro contract as the Trade Symbol: Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
