Date/Time: Fri, 03 May 2024 06:01:46 +0000
Renko with wicks - Renko Open, Renko Close, etc.
View Count: 1321
[2013-11-14 00:43:29] |
FFTrader - Posts: 180 |
Hi Sierra Chart Support, When I put in an alert condition statement in a study, referring to the normal candlestick High, Low, Open, Close I would use the text "High", "Low", "Open", "Close" right? So, what text do I use to denote the Renko Open, Renko Close, Renko High, Renko Low in an alert condition statement? Thanks, Date Time Of Last Edit: 2013-11-14 00:44:14
[2013-11-15 03:23:30] |
We updated the documentation to explain this: http://www.sierrachart.com/index.php?l=doc/doc_AlertCondAndScan.html#BaseGraphIdentifiers There are not separate values for Renko High or Low. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
